Voicemail Language only works for EN and FR
José Maia
Hello, I'm trying to set the voicemail to different languages. In my dialplan I set the default_language, default_dialect and default_voice, but FreeSwitch ignores the dialect and the voice and uses a path that doesn't exist.
Can someone tell me where this paths are defined, or any other work around?
Thanks, José
markjcrane
450
162
The additional languages need to be installed. They aren't installed by default.
wouam31
71
At one time I used this script.
#!/bin/bash
stack_sounds_get () {
read -r -p "please choose sounds install directory [/usr/share/freeswitch/sounds]: " SOUNDS_DIR
SOUNDS_DIR=${SOUNDS_DIR:-/usr/share/freeswitch/sounds}
read -r -p "please choose file ownership permissions [freeswitch]: " SOUNDS_PERMS
SOUNDS_PERMS=${SOUNDS_PERMS:-freeswitch}
if [ ! -d /tmp/sounds ]; then
mkdir -p /tmp/sounds/md5
cd /tmp/sounds/md5 || { printf "error on line: %s\n" "$LINENO" && exit; }
else
fi
declare -a SOUNDS=(
#freeswitch-sounds-en-ca-june-8000-1.0.50.tar.gz
freeswitch-sounds-en-ca-june-8000-1.0.51.tar.gz
#freeswitch-sounds-en-ca-june-16000-1.0.50.tar.gz
freeswitch-sounds-en-ca-june-16000-1.0.51.tar.gz
#freeswitch-sounds-en-ca-june-32000-1.0.50.tar.gz
freeswitch-sounds-en-ca-june-32000-1.0.51.tar.gz
#freeswitch-sounds-en-ca-june-48000-1.0.50.tar.gz
freeswitch-sounds-en-ca-june-48000-1.0.51.tar.gz
#freeswitch-sounds-en-us-allison-8000-1.0.0.tar.gz
#freeswitch-sounds-en-us-allison-8000-1.0.1.tar.gz
#freeswitch-sounds-en-us-allison-16000-1.0.0.tar.gz
#freeswitch-sounds-en-us-allison-16000-1.0.1.tar.gz
#freeswitch-sounds-en-us-allison-32000-1.0.0.tar.gz
#freeswitch-sounds-en-us-allison-32000-1.0.1.tar.gz
#freeswitch-sounds-en-us-allison-48000-1.0.0.tar.gz
#freeswitch-sounds-en-us-allison-48000-1.0.1.tar.gz
#freeswitch-sounds-es-mx-maria-44100.tar.gz
#freeswitch-sounds-fr-ca-june-8000-1.0.14.tar.gz
#freeswitch-sounds-fr-ca-june-8000-1.0.15.tar.gz
#freeswitch-sounds-fr-ca-june-8000-1.0.16.tar.gz
#freeswitch-sounds-fr-ca-june-8000-1.0.18.tar.gz
#freeswitch-sounds-fr-ca-june-8000-1.0.50.tar.gz
freeswitch-sounds-fr-ca-june-8000-1.0.51.tar.gz
#freeswitch-sounds-fr-ca-june-16000-1.0.16.tar.gz
#freeswitch-sounds-fr-ca-june-16000-1.0.18.tar.gz
#freeswitch-sounds-fr-ca-june-16000-1.0.50.tar.gz
freeswitch-sounds-fr-ca-june-16000-1.0.51.tar.gz
#freeswitch-sounds-fr-ca-june-32000-1.0.14.tar.gz
#freeswitch-sounds-fr-ca-june-32000-1.0.15.tar.gz
#freeswitch-sounds-fr-ca-june-32000-1.0.16.tar.gz
#freeswitch-sounds-fr-ca-june-32000-1.0.18.tar.gz
#freeswitch-sounds-fr-ca-june-32000-1.0.50.tar.gz
freeswitch-sounds-fr-ca-june-32000-1.0.51.tar.gz
#freeswitch-sounds-fr-ca-june-48000-1.0.14.tar.gz
#freeswitch-sounds-fr-ca-june-48000-1.0.15.tar.gz
#freeswitch-sounds-fr-ca-june-48000-1.0.16.tar.gz
#freeswitch-sounds-fr-ca-june-48000-1.0.18.tar.gz
#freeswitch-sounds-fr-ca-june-48000-1.0.50.tar.gz
freeswitch-sounds-fr-ca-june-48000-1.0.51.tar.gz
#freeswitch-sounds-pl-pl-espeak-8000-0.1.0.tar.gz
#freeswitch-sounds-pl-pl-espeak-16000-0.1.0.tar.gz
#freeswitch-sounds-pt-BR-karina-8000-1.0.50.tar.gz
#freeswitch-sounds-pt-BR-karina-8000-1.0.51.tar.gz
#freeswitch-sounds-pt-BR-karina-16000-1.0.50.tar.gz
#freeswitch-sounds-pt-BR-karina-16000-1.0.51.tar.gz
#freeswitch-sounds-pt-BR-karina-32000-1.0.50.tar.gz
freeswitch-sounds-pt-BR-karina-32000-1.0.51.tar.gz
#freeswitch-sounds-pt-BR-karina-48000-1.0.50.tar.gz
#freeswitch-sounds-pt-BR-karina-48000-1.0.51.tar.gz
#freeswitch-sounds-ru-RU-elena-8000-1.0.10.tar.gz
#freeswitch-sounds-ru-RU-elena-8000-1.0.11.tar.gz
#freeswitch-sounds-ru-RU-elena-8000-1.0.12.tar.gz
#freeswitch-sounds-ru-RU-elena-8000-1.0.13.tar.gz
#freeswitch-sounds-ru-RU-elena-8000-1.0.50.tar.gz
#freeswitch-sounds-ru-RU-elena-8000-1.0.51.tar.gz
#freeswitch-sounds-ru-RU-elena-16000-1.0.10.tar.gz
#freeswitch-sounds-ru-RU-elena-16000-1.0.11.tar.gz
#freeswitch-sounds-ru-RU-elena-16000-1.0.12.tar.gz
#freeswitch-sounds-ru-RU-elena-16000-1.0.13.tar.gz
#freeswitch-sounds-ru-RU-elena-16000-1.0.50.tar.gz
#freeswitch-sounds-ru-RU-elena-16000-1.0.51.tar.gz
#freeswitch-sounds-ru-RU-elena-32000-1.0.10.tar.gz
#freeswitch-sounds-ru-RU-elena-32000-1.0.11.tar.gz
#freeswitch-sounds-ru-RU-elena-32000-1.0.12.tar.gz
#freeswitch-sounds-ru-RU-elena-32000-1.0.13.tar.gz
#freeswitch-sounds-ru-RU-elena-32000-1.0.50.tar.gz
#freeswitch-sounds-ru-RU-elena-32000-1.0.51.tar.gz
#freeswitch-sounds-ru-RU-elena-48000-1.0.10.tar.gz
#freeswitch-sounds-ru-RU-elena-48000-1.0.11.tar.gz
#freeswitch-sounds-ru-RU-elena-48000-1.0.12.tar.gz
#freeswitch-sounds-ru-RU-elena-48000-1.0.13.tar.gz
#freeswitch-sounds-ru-RU-elena-48000-1.0.50.tar.gz
#freeswitch-sounds-ru-RU-elena-48000-1.0.51.tar.gz
#freeswitch-sounds-ru-RU-kirill-8000-1.0.0.tar.gz
#freeswitch-sounds-ru-RU-kirill-16000-1.0.0.tar.gz
#freeswitch-sounds-ru-RU-kirill-32000-1.0.0.tar.gz
#freeswitch-sounds-ru-RU-kirill-48000-1.0.0.tar.gz
#freeswitch-sounds-ru-RU-vika-8000-1.0.0.tar.gz
#freeswitch-sounds-ru-RU-vika-16000-1.0.0.tar.gz
#freeswitch-sounds-ru-RU-vika-32000-1.0.0.tar.gz
#freeswitch-sounds-ru-RU-vika-48000-1.0.0.tar.gz
#freeswitch-sounds-sv-se-jakob-8000-1.0.0.tar.gz
#freeswitch-sounds-sv-se-jakob-8000-1.0.50.tar.gz
#freeswitch-sounds-sv-se-jakob-16000-1.0.0.tar.gz
#freeswitch-sounds-sv-se-jakob-16000-1.0.50.tar.gz
#freeswitch-sounds-sv-se-jakob-32000-1.0.0.tar.gz
#freeswitch-sounds-sv-se-jakob-32000-1.0.50.tar.gz
#freeswitch-sounds-sv-se-jakob-48000-1.0.0.tar.gz
#freeswitch-sounds-sv-se-jakob-48000-1.0.50.tar.gz
#freeswitch-sounds-zh-cn-sinmei-8000-1.0.51.tar.gz
#freeswitch-sounds-zh-cn-sinmei-16000-1.0.51.tar.gz
#freeswitch-sounds-zh-cn-sinmei-32000-1.0.51.tar.gz
#freeswitch-sounds-zh-cn-sinmei-48000-1.0.51.tar.gz
#freeswitch-sounds-zh-hk-sinmei-8000-1.0.51.tar.gz
#freeswitch-sounds-zh-hk-sinmei-16000-1.0.51.tar.gz
#freeswitch-sounds-zh-hk-sinmei-32000-1.0.51.tar.gz
#freeswitch-sounds-zh-hk-sinmei-48000-1.0.51.tar.gz
for SOUND in "${SOUNDS[@]}"; do
if [ ! -f /tmp/sounds/"$SOUND" ]; then
wget -O /tmp/sounds/"$SOUND" https://files.freeswitch.org/releases/sounds/"$SOUND" || { printf "error on line: %s\n" "$LINENO" && exit; }
fi
if [ ! -f /tmp/sounds/md5/"$SOUND".md5 ]; then
wget --quiet https://files.freeswitch.org/releases/sounds/"$SOUND".md5 || printf "No md5 found for %s. Skipping this md5\n" "$SOUND.md5"
fi
if [ -f /tmp/sounds/"$SOUND" ] && [ -f /tmp/sounds/md5/"$SOUND".md5 ]; then
if [[ "$(md5sum -c /tmp/sounds/md5/"$SOUND".md5)" =~ OK ]]; then
printf "md5sum for %s passed... installing...\n" "$SOUND"
tar -zxvf /tmp/sounds/"$SOUND" -C "$SOUNDS_DIR" || { rm -rf /tmp/sounds/"$SOUND" && printf "error with sound file %s on line %s\nRemoved sound file, please run again.\n" "$SOUND" "$LINENO" && exit; }
else
rm -rf /tmp/sounds/md5/"$SOUND".md5
printf "The md5sum for %s failed.\n" "$SOUND"
printf "The sounds tarball and md5 have been removed. Trying running script again... \n"
exit
fi
elif [ -f /tmp/sounds/"$SOUND" ]; then
printf "There is no md5 for %s... installing without integrity check...\n" "$SOUND"
else
printf "something went wrong installing %s... seems to be missing...\n" "$SOUND"
exit
fi
done
chown -R "$SOUNDS_PERMS" "$SOUNDS_DIR" || { printf "error on line: %s\n" "$LINENO" && exit; }
ls -la /usr/share/freeswitch/sounds || { printf "error on line: %s\n" "$LINENO" && exit; }
printf "all done installing sounds.\n"
stack_sounds_get
