I'm having a bit of an odd issue where if an extension's timeout is set to, say, 10 seconds, an incoming call will ring ~20 seconds before going to voicemail. No matter what I change the timeout value to, it's always slightly longer than double that value before the call actually times out.
It almost seems like the call stops ringing briefly after 10 seconds, then continues another 10 seconds before finally timing out. It doesn't seem to matter what the value is changed to.
Any help would be appreciated. Thanks!
