Zammad Ticketing System Integration
644
I was asked by LayLow on IRC yesterday whether Zammad could be integrated with FusionPBX.
I had a couple of hours to spare so I had a play, here's the results:
The three files attached need to be dropped into the /usr/share/freeswitch/scripts directory. You need to edit them and put in your Zammad CTI URL.
Thats about it I think, you just need to enable the generic cti integration.
Create a destination then edit the inbound route to look like the following:
Just realised, you will have to have installed and loaded freeswitch mod_curl
apt install freeswitch-mod-curl
and add it to the freeswitch modules list.
worked flawlessly, but how the matching of number as user name and surname works?after installation on my system it just shows the number in call log not the user with matching number
Read the first post, I neither know nor care, you work that out.
i have read the post and watched the demo, in your demo i see that system shows the name of caller from helpdesk user base(?) it worked by default from Zammad side or you had to tweak this ?
Sorry, I didn't write what I thought I had and it was this: This is for you guys to take and develop, I have no interest in Zammad, its just a proof of concept for someone else with more interest and ability to take forward.
Reactions: yukon
Hi Daz, i know you said you are not adding to this and thats cool, i just have one issue, i have done like you said on an older 1.6 install just to test as we use zammad as our ticketing system, when we get a call it pops up as ringing however when we answer it doesnt change state, in fs cli i get
2019-07-23 09:30:09.125592 [ERR] mod_lua.cpp:203 /usr/share/freeswitch/scripts/zam_answercall.lua:2: attempt to concatenate a nil value
stack traceback:
/usr/share/freeswitch/scripts/zam_answercall.lua:2: in main chunk
any ideas plz? once i get this working i will expand on it hopefully, just doesnt seem to wanna work
Kurt
ahh ok, just thought you may know what the error means thats all, i know you are not actively using it just i have been trying for 2 days lol ...
DigitalDaz, thanks for this!
If anyone is facing issues, look at the screenshot of the inbound route, everything has to be set in order for it to work!
nil value: most likely you have not defined original_to and original_call_id
hangup not working: attempt to index global 'session' (a nil value), you might have forgotten the export session_in_hangup_hook=true
works great! thanks again.
Do you mind if I take this and put it up on github and add some configuration file to it so one does not have to put the url in every file?
@lcx_at Please go right ahead, this is exactly the way I like to see the forums working, cooperation and collaboration :D
Hi, I use this script and works well.
I have some trouble if I use that in combination with mod_callcenter: in particular, the event execute_on_answer and api_hangup_hook doesn't fire if an agent answer or hangup a call.
Do you have an idea why this event are not launched with mod_callcenter?
Thank you!
This is exactly the way I like to see the forums working too:) Thank you very much for creating this forum. From giants like Cisco and Dell to almost all small and large open source projects, they all have strong community support. Hopefully, the community support for FusionPBX will grow as well. It is definitely an added value.
Just realised that mine has stopped working. Think this is down to us stating to use time conditions.
