Call center module not refreshing users
UKVoipbunny
Hello
Running FusionPBX 4.3 and I'm able to add users into call center queues but when I delete they are still in the queue list and recieve calls. I have flushed memcache and also reboot server to no avail.
Adding more and more users works fine. It's simple trying to remove users that is not working.
Please help driving me nuts...lol
420
The simple answer is not to use master on production systems really.
I expect you will have to manually remove them from the db
Look in
v_call_center_agents
v_call_center_queues
v_call_center_tiers
UKVoipbunny
When I upgraded it didn't give me an option not sure how to change.
As for database in the tiers table those users are not there for that queue. In the other tables I see no way that the user links to the queue.
Tuyennt
Look in
v_call_center_tiers
Hi You,
You can help me design call_center system with multi server.
I realy thank you!
My email : ntrongtuyen@vnpt.vm
420
I wouldn't choose FusionPBX for dedicated call center. Look to something like Vicidial instead, its probably better suited and is tried and tested.
Reactions: Tuyennt
Tuyennt
Thank you, Plz tell me why you choice Vicidial. I see freeswitch have performance more than asterisk. Freeswitch play well with about 1000 calls concurrent on server.
