I've got a strange issue at one of my FusionPBX tenants. A call comes into their main number, first to a time condition, which routes to a ring group with 'Simultaneous' ring strategy to 5 phones. On an incoming call, lifting the handset, pressing answer, etc, doesn't pick it up, just takes the phone off-hook.
'Pickup' appears on the screen, but lifting the handset directly doesn't answer it. If I press the 'Pickup' button, I then have to touch the right incoming call, then click 'Answer'.
If you call directly between two phones, or on a direct DID inbound call, no problems answering normally.
Is there a way to set this up to just allow them to answer directly without pressing extra buttons consistently?
These are Polycom VVX phones, in case that makes any difference.
