A Amit Iyer Member Feb 6, 2018 60 12 8 30 Sep 13, 2019 #1 Hello, I want to set a call limit on Ring Groups where i can allocate Daily incoming calls, Total Incoming calls and set the Concurrent LImit to the call center or Queue. How can i do this ? Also how do i get the report of a call center queue?
DigitalDaz Administrator Staff member Sep 29, 2016 3,134 615 113 Sep 26, 2019 #3 There is absolutely nothing in the existing configuration that allows you to do this. It would be completely custom work.
K KonradSC Active Member Mar 10, 2017 166 99 28 Sep 26, 2019 #4 No comment on call center queue reporting. Check out call_limit. You can limit concurrent calls and the rate of calls for an interval. https://freeswitch.org/confluence/display/FREESWITCH/mod_dptools:+Limit I use something like this in my dialplan to limit the rate of inbound calls to each destination. This is 2 calls per second. Code: <condition field="${call_direction}" expression="^inbound$"> <action application="limit" data="hash ${domain_name} ${destination_number} 2/1 !USER_BUSY"/> </condition>
